I lost the mag side rod bearing & cracked the case on my 09 800R. I have an 07 lower end which was a replacement shortblock in 09 for the 07. (not the original 07 stock engine) Other than the lower plate, are the cases the same? The PTO stub is broken on the 07 crank. If the cases are the same I could just order an 09 crank. Also, what's different between the cranks? I've been told that the mag end taper is different but I don't know that to be a fact. Could the ends of the 09 crank be put on the 07 crank? The 07 crank & case is like new, less than 500 miles.
