Does Ski-Doo or someone else make a clutch maintenance kit for a 2007 Rev 800? Is OEM or aftermarket best? Part numbers? Thanks.
Hi...use this one.
Primary clutch
http://www.ibackshift.com/article/-162.asp
Maintenance.
Since 2008 there have been 3 updates on clutch wear parts for the tra-7 primary.
The maintenance kit below gives the latest/greatest wear parts. Once installed they take about a ½ tank of petrol of driving to “break in” and start to perform with consistency.
Maintenance kit for drive pulley (buy from local skidoo dealer)
1 spring cover assy, 3 rollers, 1 bushing, 6 slider shoes and o-rings, 1 circlip, 3 cotter pins & lever axles 2008~10, 800PT & Etec
BRP#415129627
Where in Idaho are you? That bushing can be a pita at times.
