I just installed a new 800r stock motor into my rev with an RK Tek head. The first night I completed the motor install I started it 3 times, for short periods of about 1-2 min. each to check for leaks and get the air bubbles out of the antifreeze lines. The last time I shut it down there as a beep from the gauges which word just fine each time I started. The next morning I rolled it outside to get if off the ground and run the track out a couple of times. Low and behold I didn't have any type of electrical power. I checked the 2 fuses that I could find up by the head lights and they were ok. I then took off the mag and stator to see if I had pinched a wire and ground it out. All looked good in that area. I also checked all my plug connections and they were good. Please let me know your thoughts or if anyone has had this same type or similar issue.
Thanks!!
Thanks!!
