07 m8 TPS or TSS By Pass HELP!
Duzzi
Does anyone know how to bypass TPS or TSS?
Throttle tension seems loose.
Wont start. Continue to die.
Sled died on the hill and had to be towed out.
Any help would be appreciated.
Rev up to 4k then died. Would idle. Without hitting throttle would rev up to 3800 on its own then bog down and die.
TSS can be bypassed by unplugging the switch at the throttle flipper or unplug it under the hood by the steering post. I think it's the big main plug going to the bars but I'm not positive.
Turns out. All I had to do is take the throttle plastic cover off and unplugged it. The Color for the 07 m8 is black and white and it fired right up.
I bet you wish you would of done that on the MTN.
My 09 m1000 had issues, I disabled it with a small screw.
