07 m8 mod advice please
I have an 07 M8 with black dimond hood/airbox kit, SLP y-pipe pipe and can, boss seat, can I get some advice how to pull some more power out of it on a budget. If I had the extra five grand I would just turbo it but I don't so it runs pretty good but I want it to run better.:beer;
get the new boss nitrous oxide system...no controller needed...seperate little bottle for the race gas...best way for RELIABLE 40hp gain for under 1000 bucks..then just invest into light weight parts..
your motor will hold up real fine...these New boss kits are supposed to be the new standard for reliability..people were getting years of reliable use on old kits...look at my mods in my signiture...no n.o.s and trust me i will have it soon...again your motor will be fine if you use it properly...years of use
just get ahold of BOSS...actually a fella from Boss was posting on here...but anyway just get on their web page (google)and phone them..their web page may not be up to date with the new system so make sure you talk to someone..
weights
So I'm running 73 gram weights and I'm only hitting about 7600 then when I get up high (around 8000) only about 6900. I've been told 68 grams is perfect for my mods what do you think
Weights
You should definately try running 68's. peak power with the pipe set up is 8100ish if you get that i guarentee you will pleasently be surprised. I'm running slp pipe set on my 07 m8 and what a difference. It runs with stock m1000's now. Hope that helps
Thanks
Thanks man 68 is what I've been hearing it just seemed like a big drop in weights but I'm going to try them out this weekend. Thanks guys for the info
