I have a strange mid range bog in one cylinder I can't clear up. I have a 07 or 08 bd race gas kit however I run it pump gas with the pump gas acutator and run it around 6 pounds of boost.
When I get on it it bogs like one cylinder has a fouled plug. Clutch side cylinder had wet plugs/ pto side ok.... clutch side temps 670F max/ pto side 880F Max after getting on it... checked spark and both sides good output... compression both around 100 psi... reeds looked ok...replaced and calibrated both exhaust valve cables... clutches in good condition... fuel was 47/85 on the boon docker... replaced ccu last year, the lights and reverse work good... the speedometer stopped working with the ccu last year so i don't know if it has any codes I have not replaced that yet... I'm stumped but suspisious of electrical.
Anyone have any ideas or experiance with some freak things happening I could check.
