M
mblanken881
My sled runs very strong on the top end. No complaints there. The bottom end seems a little rich. Running 38 PSI fuel pressure. The problem occurs when after a short WOT then let go and get right back on it. When I get right back on it, it's like I fouled a plug or something. I have to let the sled get back to idle to clear back up before I can get on it again. This doesn't happen if I've been on the throttle for a while, only after a short burst of WOT. It seems to be happening around the 5000 RPM range. I added fuel to the 5000 range up to 10 across the board and it was considerably worse. Then I went below Boondockers recommended numbers of -2, -4, and -6 to -4, -6, -8 and put the hi at 3000 to -8. This helped considerably but it still does it. The EGTs atthe 5000 range with my numbers are at 1250ish.
Any advice.
FYI - I have the older boondocker box and running ~12 PSI of boost.
Thanks,
Mike
Any advice.
Thanks,
Mike
