I was out looking at the 2007 arctic cat m6 my son rides it's been loosing coolant and today I was looking at the backside of the engine and found where it was leaking coolant out of the crank case bolt on the right side right behind the coolant hose I cleaned it all off and then started the sled and watched it start dripping out of the bolt area right behind the pull start assembly was planning on doing a top end kit but this makes me wonder if I need to split the crank case now in order to redo seals in there also found the typical m series steering post crack along the inspection and trying to find a bracket setup to replace the cracked bracket and upgrade it to a stronger setup as I'm in there and was doing a bdx adjustable steering post kit on it anyways and need to figure out some options I seen a post on here from a guy who built them but not sure if he can or not any help or advice would be appreciated
