07 m1000 NO TOP END
i ve got a 07 m1000 with no power on the top end, it pulls about 7000 rpm and sounds like a tractor, no lights flash, runs fine at an idle and up to about 4500- 5000 then just starts "i am geussing loading up" and runs like crap, it;s got 120 both sides compresion, power valvles seem to move freely when i slide them up and down, it was running ok then within about a 2 minute s it just started running like well crap.. any ideas would be great ....
Powervalves out of adjustment. Should be 34.8-35.2 mm
Cracked can, broken weld.
Barometric pressure tube on ECU plugged.
These are the first 3 things I would check.
I was about to say one bad powervalve cable when I saw this. Thought it would always throw a code but learned this last sat. Friends cat would not pull on top but no codes. One powervalve cable was disconnected completely. Only codes if both are malfunctioning I guess
