07 M1000 crankshaft w/ 4 post clutch f/s
i didnt have the puller for it !it was all sold till you run off at the mouth ! So now the clutch is off but trashed couse didnt have the correct puloler thanks you !@@#%#@
whats the status o the project?
Do you have a good crank for sale?
Its easy to get the clutch off even now, just pour water in the hole, get a cheap bolt from the hardware store and some natural gas tape, cross thread tape and then get a good seal (tape and bolt).
next take an impact wrench and torque the bolt into the clutch. You could even use the stock clutch bolt.
It will pop the clutch off!
If I needed the crank I would have bought the setup as is, not a bad price for crank and clutch.
My crank broke off behind the clutch, I found a crank but wanted to save the clutch
Ian
