07 dragon front end
The weekend I was eager to go riding. With my sled behind my house and 4 ft of snow in my yard I towed my sled out by the skies. I know super bad idea. But with the plastic bumper being so cheap I didn't wanna break it now my left ski is tilted in l----\ I can't see any physical
Damage on the aarms or spindles or the skis but the ski is def towed in aswell as slightly leaning in. What's the most comman to fail?
Thanks
Damage
Did you just twist the ski loop? If you damaged an a-arm, you should be able to see where there is paint cracked/chipped/missing. My wife's 07 has a twisted loop, and has had for a while, making it look like the whole front of the ski is twisted. Heat gun and twist it back. And next time, tow it from both spindles at the same time.
Don't worry about it! That is a perfectly fine way to tow in a sled. I towed in a friend 2013 pro that way as the spindles cut the mule tape multiple times and we were running short on rope. give it a couple rides or weeks in a warm garage and the skis will go back to like new. If not take a heat gun to it like mentioned above
It's hard to imagine you could bend something by just pulling it by the skis. If there is nothing apparently bent you can make adjustments for toe in with the tie rod. You can make adjustment on camber with the adjustment on the upper a-arm where it attaches to the spindle.
