07 dragon extrovert to rail tip clearance
if you realy want to check take the shocks out of the skid no track and rock it front to rear 1/2 to 3/4 is plenty ,the best thing to do is remove the tips and put a anti stab wheel kit on..
if you can take the tips off and trim the rail back an inch make it so you can put the plastic tip back then grind the plastic tip back some also. I moved my skid back an inch and did what i meantioned above its what they use do do on the old chassis's i guess i just havnt given up:face-icon-small-con
