07 Apex GT28 $6500
this is a sled that will pull your arms off if you want to i'm just tired of the seld ready for a new challenge no bull**** it is an 07 BD kit haven't had very many problems, just pulled the sled apart last week and went over bolts and hose clamp and changed the oil has provided lots of fun weekends. just changed the drivers on it also. ran anywhere from 10lbs to 20 plus lbs of boost with no problems other than a little blow by but the brether is in the belly pan, with 50/50 fuel and double head gasket. you can reach me at 406-366-1637 if you have question call me.
07 Apex MTX SE with fox floats
Location?
Does it have a fuel/air ratio gauge?
I've been told that some of the earlier kits came with a woven flex joint at the end of the header just before it went into the turbo. When combined with that small diameter tailpipe and all that heat, they had some issues with blowing it out. The updated header from BD has a Burns Stainless slip fitting instead of this flex joint. Is yours the updated header?
And are you running the original 2" tail pipe into the tunnel or have you updated it to 3"?
Also what's been your experience with the crank case breather spitting oil? Do you have a oil catch on it or..?
How about a head shim? Does your Apex have a head shim in it or is it running stock compression?
Send pics to ice_cold_snowmobiler@hotmail.com ASAP
What kind of track is on it? Camo Extreme?
Any mods other than the turbo?
Has the Boondocker box been upgraded to ADA?
Thanks.
