07 800r wont idle without choke. Seems to be very lean on low end circuit??
skank
Anybody else had this problem? ran fine when put away last year but now it seems its not getting enough fuel. Runs great mid to top end. Crank seal? plugged pilots? tps? Help me out fellas!
Yupper on the pilot jets....make sure you not only blow through the pilot jets but also run a small wire through the hole. I had the same problem on my 09 and cleaned the pilots with carb cleaner and also blew through them. Thought they were good cuz I could see light through them. NOPE. Had to tear carbs apart again and had to run a wire through the jets...all was good and ran normal after that.
