ok, so I have an 07 summit x 800R and I have heard people talking about a mod where you add a thermostat. I was just wondering what this mod is and what the gains are from doing it?
Thanks
Evan
Thanks
Evan
gains=not taking out your motor.
Talk to turbo al he has all the info you need.
there is no thermostat on the 797... i wouldn't put one on...ok, so I have an 07 summit x 800R and I have heard people talking about a mod where you add a thermostat. I was just wondering what this mod is and what the gains are from doing it?
Thanks
Evan
I never saw a need to add one on my '07. Once again, the aftermarket will want to sell a thermostat kit if a sled comes without one, and sells thermostat delete kits if a sled comes with one.
LOL- thats pretty funny...the delete kits for the HO motors has a 2 fold advantage, 1 being NO stuck thermostat blown motors and 2 making a little more hp from a motor running around 100 degrees...as for the 2007 the ONLY reason the cranks went early was from a poor case clearance/machine spec...the 2008 cranks are the same but a NEW machine spec for the cases...the stat on the 08-09-10's is EPA related ONLY...BJ
People that didn't have crank issues on 1000 SDI's and 07 800R's must be trail riders.
In response to RKTs post. Steel expands .000057" per inch per degree of temperature change above 75° deg F. So if the crank gets 75 degrees hotter than the case it expands 0.0043". Raising the case temp to 140° lessens the temp difference. Is this possible?? Is this outside the tolerances?? That is what I was told by Skidoo was the problem with the 07' sleds, too much cooling in the monoblock case and the cranks were made to 06' specs. I love my 07' but would be hesitant to buy one that did not have a new crank with better tolerances.
'07 800R owner here with no crank issues yet and no T-stat retro-fit(2900 miles on original 800R). Anytime you want to go ride the "trails" with me Dave, you're welcome to come along
