The single spring that is in the 800R rave valve does it go in between the rubber bellows & valve piston.....or does it go between the valve piston & the rave cover???
Last person to touch mine was the dealer when it was taken in for the destroyed motor, took the valves out today and the springs were between the cover and valve piston.
The manual says it goes in between the rubber bellows & the valve piston..... all the microfiches say it goes in the bellows.. why would the dealer put it under the cover?
somebody set me straight please
thank you
travis
thank you
travis
