07 800 need help
M
McLaughlin_7
New member
got a 07 summit and rsan fine last year went to get it out this year and it doesnt seem to run right starts up just fine and idles if i backup and then go forward a little bit it wants to die out like it running out of fuel and and also does the same thing every now and then when i am going forward cleaned carbs and checked everything with fine tooth comb dont know where to go next and suggestions would be great thanks
Did you put new fuel in it? Could be bad fuel, hard to say just idling and going back and forth though, need to blow the cobwebs out on a ride even if a short one to see where it's at. It's always worth checking compression on an 07 though. We just put pistons in a one owner 1500 mile sled that had pistons done by ski doo in 07 under warranty. Compression showed 30 pound diff between cylinders.
