SO did some stuff to the sled (took apart and cleaned power valves, took off exhaust, put higher riser on (involved taking out cables to bars) moved tail light)
And now the sled won't idle, at all, starts up on one pull, I can rev it up and it runs fine, but if it gets near idle it will die.
Power valves are in correct, all wires are hooked up (I think) any ideas?
Could wires to the bars cause that?
I tried to adjust idle screw (it idled low before) and no change.wont even idle fast. Made sure I got the exhaust on tight... Choke isn't pulled
It did backfire once, when I was trying to keep it alive with the gas..
