06 rev 800 goes beep beep beep (help)
Ok, went and rode today. About 1/2 into the ride, every now and then I would hear a beep. NO check engine light, no low oil and not hot either. The longer I rode the more often the beeps got. I wasnt on a mountain ride with the boys, i was on a co-ed ride with the girlfriend and 2 other couples. If I would hold a steady 5 grand no prob, blup the throttle to a little over 6 grand and I would hear a beep. Steady at 7grand and I would get a steady beep beep beep. IT DROVE ME NUTS!!!!! When we got a couple miles before the snowpark we were zipping along at 50-60mph and had good rmps going. Pulled off the key put it back on and it didnt beep again. Also dont know if it is connected but the sled is not running great above 7grand either. And yes, everything that I can touch and see is pluged in. Any help would be appreciated.
the relay fixed my motor running hard over 7000, and i still had lights and gauges. I dont understand how a new relay from napa will not run my gauges, but the old one will. Must be the relay's right?
lights and guages
Do the lights and gauges work? If not, I agree it's a relay....NAPA #AR201
Lights and guages work fine. I didnt notice everynow and then when at idle the tach would bounce from 0 up to 1500 and the lights would flash. I can pop a relay in sled, should have done that along time ago anyways. TY!!
beeping problem
Check the connector at the ECM above the pipe for bad pins in wiring they will be turning green if it had water setting in it. We had to have a new wiring harness and ECM installed when we had the same beep, beep every now and then. Sled did run just fine,but you would get a light on the gauge sometimes.
got mine figured out:face-icon-small-con Didnt think to look at the part #. just figured that napa would give me the correct one seeing's that i gave them my old one to get a new one.:face-icon-small-con. :laugh: they gave AR274, a similar relay, but the wrong one. it looked the same, same numbers and everything.:face-icon-small-dis. the AR201 acctually looks a little different. No hole on it to ziptie to the frame:face-icon-small-sad. But it works correctly:face-icon-small-hap. I'll take half the blame for this one. Just a head's up,,,,,,, AR201!
