T
Tackbtch
ACCOUNT CLOSED
06 800 , So at the end of last year we lost a piston and rod bearing. Long story short I install a reman crank and pistons. And wouldnt ya know it the sled now uses darn near two Qts of oil per ride...70 miles or so. I took the sled to the dealer for some other issues and asked him to look at the pump as I may have the adjustment wrong. He thinks the pump is fine and that I may have damaged the inner seal on the crank witch allows oil to enter the case from the water-oil pump shaft I did take the oil pump off and ran it on a drill for a short time to make sure it was pumping oil. Could I have fubared the pump so that it runs wide open all the time....would be a way easyer fix than to deal with the crank Any thoughts ??? Thanks Dino
