can't get mine running either
Can't get mine started either,I have 2 06 M7 so I've swaped out parts trying to diagnose, I guess I'll try the tapping on the Throttle bodies and cleaning the Smart valves in the tank before I swap the wireing harness. I was thinking my problem is related to the voltage because I'm only getting 3 volts on the red wire going into the tank.
tThat was untill I just pulled the cord and it started up right away , so to keep it running I played with the boondocker box, and while it was running the voltmeter ran 12-15 volts,then it died and can't get it started again. could it be the boondocker box? it seems to be getting to much fuel when it ran for a short time.
just thought I'd put my 2 cents in, maybe together we can figure it out, what is the voltage on the red wire going into your fuel tank ? It should be around 13v,
