06 m7 handwarmer wiring?
I bought a new set of handwarmers for my M7. Got sick of not having any handwarmers on really cold days. I've got 3 wires coming off the old elements, Yellow, Green, Black. Which wire is HI, LOW, Ground? Thanks ahead for any info!
i forget , but you can follow them down to the juntion with the switch wires ,, then follow those up to the switch and it will tell you
Jake,
On a 2005 M7, which should be the same as the 2006 and 2007 m-sleds:
yellow=high
green=low
black/brown=ground
If you have RSI's, which I ran last year and work pretty good, you will splice or solder:
white - yellow
blue - green
red - black
