57/63 is correct. I just upped mine to 59/61 as the 800 bigbore was walking the belt right out of the clutch. Shane, you might need to gear up your 900 as well. I probably could have gone higher.
Thanks Sheldon. What pipe/s are you running? Did you go with BDX gears?
But with the 800 BB, I'm running 75 grams and still over revving a bit,
Did you catch that Shane, remember what I was saying a couple weeks ago on the mountain when we were tuning yer sled. About how it needs more weight . Sheldon's running 75's with an 800 Big bore and still over reving. Im having the same issues with my 900 D&D at 72 grams. I think we should order a couple sets of 75's. I learned this first hand from Kenny at Listers in Whitehorse, we're banging off the rev limiters and the efis are over fueling our sleds causing bogs and "broken thottle sensor" like issues. Id say its all coming together..............
on my sea level sled im running 77.5s atm but wil be going down more as im only getting 7600-7700 ( 7900-8k target)
this is on a full mod 925 Speedwerx, 10.4 65/ 55 ( i think ,, firecat gearing anyhow ) 1.6 track 44/40 helix cat ornge with shift assist, milled primary
