M
Mnt bound
First I pulled the plugs out to check for spark tuned it over and coolant came out. So I pulled the head off this m6. The Cylinders are full of coolant. Cylinders walls look good and the pistons look good from the y-pipe and top. Looks to me like the inner o-ring failed one both sides and the head bolts didn't seem that tight. Working on this for a family member. My questions are:
If it was yours would you:
1) take it out and apart compleatly dry it out and replace pistons gaskets and head o-rings.
2) Take the cylinders off dry it out and put new pistons, Base gaskets and head o-rings.
3) Take the cylinders off dry it out and use old pistons, base gaskets and new head o-rings. (provided they look good once apart)
Also I did a search but couldn't find any threads on how to get the motor out.
I know there has to be some if you know let me know.
Thanks,
MB
Thanks,
MB
