kinda new to the ac skids, did a search, lots of good info, never really saw anything directly aimed at the 05-06 m series. what the best setup for maximum weight transfer? any and all input would be greatly appreciated. thanks.
I put the holts relocates on and went to the 07 rear arm. The 07 rear arm is longer therefore losing the bracket where it bolts to tunnel. So if you order the arm dont forget to order the axel with it. It was under 100.00. Also you can adjust your limiter straps for weight transfer.
