H
First sled ive had in awhile so im a newb again to site. So here we go...
Purchased a 2006 crossfire 700 with a running issue. Thought i had it figured out but was wrong. first off a description of sled:
-Stock 700
-Aftermarket intake. think it is a combo of SLP and Speedwerx. has added front vents as well as having holes drilled into top of air box.
-Has aftermarket M style can on it. Has M7 side panels and nose piece so exhaust can exit behind front suspension. Ceramic coated stock pipe and y pipe.
-Vented side panels.
-Oil pump delete kit. Mixing 32:1
So the issue im having is a bog at around 6500-700 Rpm. It is VERY intermittent bog, id say is 50/50 ratio of bog to lifting skis. If you take off after it has been sitting for awhile the sled runs awesome for mile or so, then develops the bog. Wont gain any RPMs past 65-6600. once its warm it bogs as well. When riding down trail and crack throttle it will sometimes bog, and sometimes take off like its supposed to...
Things ive tried:
- 125PSI compression in both cylinders.
-Good cardboard color in Y pipe. slightly darker on plugs.
-Taped off extra intake vents.
-Found a bad coil in stator, swapped stator and timing pickup outside flywheel with known good parts from buddies sled.
-Throttle safety switch/kill switch disconnected
-Checked secondary clutch for stuck rollers etc.
-Check.clean exhaust valves, checked cables. servo motor works correct when running on stand.
-Added some iso-propyl to gas and cleaned smart valves in tank.
Really lost and dont know what else to try. Tried doing some searches and never really found answers. just other things to try with no luck. Hoping someone has had this issue,solved it and is willing to point me in right direction haha.
-Stock 700
Things ive tried:
