have most of the chassis looking to part out this was boondocker sled that caught on fire several times the harness and brake line and the right side cooling lines are damaged. the front end, a arms, spindles and shocks are in great shape chaincase has black marks but look good other wise I can provide pics here is the parts list motor is sold and primary along front plastics. pm for questions
Voltage regulator $50
apex crank in good shape $200
all internal components minus one rod, piston, cams, and cam gears $300
delta box with steering assembly $50
chain case and all drive shafts and sprockets with wahl 7-tooth 3.0 pitch $250
front end a arms spindles and shocks $150 left side left
skis $175
162x16x2.25 maverick track $100 badly damaged missing lugs
162x16x2.5 camo gen 1 extreme 6 lugs tore off $100
rear suspension minus inner idler wheels and rails $100
fuel tank $40
tank cowl red in color $50
ignition switch $20
All handle bar controls $50
skis $175
fuel tank $40
ignition switch $20
