06 900 tail light problems!!! HELP!
MNSledShed
Light bulb is good but i cant get brake light to work!!! Tail light or running light does but not when you hit brake! Any suggestions! Headed on a trip in 8 hours and ive racked my brain on it! Thanks!
Its in the left handlebar control. u will have to remove the rubber piece over the handlebars then pull like 4 little screws from the plastic piece and it should sit in there held in with another screw i believe.
I could be wrong tho. its been awhile since i did it.
Should be number 8 in this pic.
make sure you check the wire connections to the switch first to make sure it is not just a bad connection.
Always start by checking the easiest things to check and least expensive to fix.
If you haven't already... check the connector for the tail light under the fuel tank this spot keeps alot of moisture and I have had to clean corrosion off the connector pins twice now.
You won't have to remove the tank, just remove the 2 tank nuts and lift up the back end a little to find the connector.
Like Z-Man said...try the easy/free fixes first
