06 900 starts idles for 10 seconds then dies
B
brent9k
New member
I have an 06 900,
it was running good and then it just stoped running as i was going down the trail. i tried to restart it and it will fire up on the first pull it idle for about 5 seconds and then dies. It will always fire on the first pull and idles fine but like i said it dies after about 5 seconds of idling.
If i try to push on the throttle it will die.
I let it sit for a day and went back to stat it and it fired up in 3 pulls and idles for about 1 minute, but as soon as i hit the gas it just died.
Then it went back to starting on the first pull, idle for 5 second then dies
please help
Sounds like you've got a fuel issue. When was the last time the fuel filter was replaced?
You should verify fuel pressure at 58PSI (EDIT: 116 PSI for 06) when the sled is running, there is a test port on the fuel rail that you can hook a gauge to. There is a pressure regulator in the system that may have gone bad, or the pump itself may be weak or otherwise failing.
hey
i was having similar issues with mine.
the things i was told to look for were
chassis relay
capacitor
stator
fuel filter
bad fuel
fuel psi
it ended up being a bolt had come loose and fallen and damaged the stator it munched a few or the wires so it would start then short out and stop
hope those help u
