06 900 ski alignment
The left ski outside edge is angled up and I can't figure out why. I tore the front end out thinking I'd find a bent arm, but everything checks out fine. I have the Holz spindles and sly dog ski's. Other then the front suspension is there anything else I should look at>
Yes the camber tends to run 'fat' with Holtz spindles, but it's no big deal, personally I like the camber a little to the plus side, but both sides need to equal is the important thing. So start by adjusting 'worse' side first, as one adjustment will affect the other. (will need camber alignment bar) Also set toe in/out afterwards. Good luck.
I don't think there is enough adjustment with as much angle as I have. I'd have to say the outside edge of the ski is an inch high where the other ski is flat. I'll see what I can do. Thanks for all the help..
Warped ski from being clamped to a trailer for too long??
Pull the skis and do the standard Camber check in the Holz spindle instructions (if you dont have them.. you can download them from the HRP website)
