hey everyone so i have onther qustion and brain teaser for you all. i have a friend with an 06 900 dragon with a slp motor in it the problem is that when the engine is warm and you shut it off with the key it wont start back up right away it takes ablut 10 min of pulling it over befor it will start again but if you shut it of with the engine stop button i will pop right over on the first pull. and if sled is on a steep hill and you shut it off with the key the only way to start it back up is to dump some fuel strait into the cycilnder but again if you use the botton on a hill to shut it off it will start up with one pull. anyhelp would be great it dont make any sence to me it should matter i wouldnt think if you turn it off with the key or the switch i should still start up on one pull when it is warm.
