06 800 bad bog?
Working on this 06 800 Summit trying to figure it out. The sled starts and runs fine on the flat it pulls 8000 rpms but when you go and lay it over in a carving turn it bogs and falls on it face until you right it then it runs fine. It does not matter witch way you turn left or right. worked clutchs over,pulled the carbs off cleaned and pulled the d slids out and pulled the covers off both carbs and checked the orings and they where fine, did compression check 170 psi in both cylinder. What else should I look for?
