I recently have a issue where my reverse cycles between forward and reverse at idle or when I let off the gas.
Anyone else experience this????
The first time it happened I had it off and when I started it the reverse light would blink and it just sat there cycling between forward and reverse. The only way I could get it going was to catch the cycle on the forward position and then hold down the reverse key and give it gas, once the engine engaged then it would stay forward until I let off the gas and it would start cycling again.
Now it seems to stay in forward when 1st starting it but as soon as you give it a little rev and let off it automaticlly switches to reverse and visa versa.
I'm stumped at this point cause I'm not finding any shorts and I took the handle bar switch apart looking for ice or shorts but everything looks good?
Thanks in advance for any lead on where to look. How does the TPS affect this issue?
