A
i got a 05 800 ho powertek last winter got and accident with it , take it all appart and fix the body, check the engine and got a crack in the base au engine , take the engine appart and replace de crank and base , put the ski-doo back togerter and now only spark one a wild, major off the time no plark , check the trigger coil got 263 ohs , check all the wirring found nothing , check voltage out off regulator 4.3 volts when i am cranking , check the dess switch work check the kill switch work even unplug it still no spark , take the ecm off and try it on and other sled work fine, any one have and idear what the probelem????
