2005 m7 153" slp twins, timbersled intake, bd box riding 10,000-12,500' in about 2 feet snow, with all stock clutch setup for 9000 and over, yellow primary white secondary spring and 65g weights. while climbing my sled would only pull around 7100 rpms it would do a little more at lower elevations. on a trail at top speed was only getting like 7500. i just installed shift assist in secondary along with the bd billet deflection adjuster. I was getting 7800 in the flats before installing shift assist and deflection adjuster. I hate to go to lighter weights as 65s are already light, would a stiffer primary spring help. also should i try cranking in the secondary spring, or even try a stiffer spring like the cat orange everyone talks about? sorta new to clutching just what i know from these forums thanks.
