05 M7 diamond drive toast!
acdc
New member
14
1
3
Inkom, ID
Lost the planetary gear, transfer gear missing teeth and misc bearings and seals,
parts are going to run me $350. Anything cheaper out there?
Just changed oil in gear case 200 miles ago. Didn't pull the transfer gear out and inspect planetary, but I think problem started before I bought the sled. New to the diamond drive/arctic cat, suggestions?
spoon
Wrenching to ride is half the fun
1,240
644
Kootenays, BC
BDX drive and what he has are same. Rebuild using BDX parts or buy the used one for 200$ and go through it before using it. Check planetary closely as that is usually main cause of failure.
Paul27
121
91
Reno, NV
These are prior DD threads:
http://www.snowest.com/forum/showthread.php?t=46241 (DD oil)
http://www.snowest.com/forum/showthread.php?t=151644 (original & best DD info)
http://www.snowest.com/forum/showthread.php?t=194667 (2007 DD w/ mechanical reverse)
http://www.snowest.com/forum/showthread.php?t=196088 (DD gasket)
http://www.snowest.com/forum/showthread.php?t=197407 (general DD info)
http://www.snowest.com/forum/showthread.php?t=199025 (DD gear ratios)
http://www.snowest.com/forum/showthread.php?t=202707 (2008 M1000)
http://www.snowest.com/forum/showthread.php?t=207098 (2009 M8 turbo)
http://www.snowest.com/forum/showthread.php?t=208522 (broken DD gear)
http://www.snowest.com/forum/showthread.php?t=208831 (2010 M8 4203/5203 bearing)
http://www.snowest.com/forum/showthread.php?t=209383 (old DD w/ mechanical reverse)
http://www.snowest.com/forum/showthread.php?t=210054 (2010 6203/5203 & rubber boot)
http://www.snowest.com/forum/showthread.php?t=210151 (describes DD & drive shaft mods)
http://www.snowest.com/forum/showthread.php?t=213279 (2007 M1000)
http://www.snowest.com/forum/showthread.php?t=221850 (DD gaskets)
http://www.snowest.com/forum/showthread.php?t=229107 (DD / drive shaft rubber boot)
http://www.snowest.com/forum/showthread.php?t=233914 (gear alignment)
http://www.snowest.com/forum/showthread.php?t=246922 (2010 HCR 6203/4203/5203 bearing)
http://www.snowest.com/forum/showthread.php?t=248066 (2010 M8 6203/4203/5203 bearing)
http://www.snowest.com/forum/showthread.php?t=269361 (DD oil)
http://www.snowest.com/forum/showthread.php?t=278834 (2011 M8 6203/4203/5203 bearing)
http://www.snowest.com/forum/showthread.php?t=284137 (2011 HCR dis-assembly & bearing)
http://www.snowest.com/forum/showthread.php?t=300771 (2009 M8 tear-down & shaft trim)
http://www.snowest.com/forum/showthread.php?t=303344 (how to change DD oil)
http://www.snowest.com/forum/showthread.php?t=308061 (2011 M8 tunnel / drive shaft)
http://www.snowest.com/forum/showthread.php?t=310238 (2011 PG TM8 bearing failure & 2011 HCR DD track-shaft)
http://www.snowest.com/forum/showthread.php?t=311953 (DD oil)
http://www.snowest.com/forum/showthread.php?t=322419 (DD pros & cons)
http://www.snowest.com/forum/showthread.php?t=324077 (2009 M8 bearings)
http://www.snowest.com/forum/showthread.php?t=325231 (2011 M8 bearing change)
http://www.snowest.com/forum/showthread.php?t=328688 (DD oil)
http://www.snowest.com/forum/showthread.php?t=357243 (DD oil)
  • Like
Reactions: backcountryislife
acdc
New member
14
1
3
Inkom, ID
Thanks for the help everyone.
J&L Snowhawk; The gear ratio on the one I have is 57/63, is the one you have the same? don't know if they made different ones for the M7.
