05 king cat 900 efi need help with fuel pump voltage
Poocat900
2005 king cat 900 efi. Fuel pump went out and was replaced. The sled will start when fuel is put in cylinders and dies once the fuel is burned off. New fuel pump works when hooked to 12volts. When I try to start the sled by putting the gas in the cylinder the voltage at the fuel pump while it is running is at about 5-8 volts. Do I have a bad stator or what voltage should I be seeing at the fuel pump.
Any info is appreciated thank you.
Sounds like stator or voltage regulator to me.
Sent from my Pixel 3a XL using Tapatalk
