05 fusion suspension swap
So I'm planning on putting a 09 assault 146" skid & shocks under my fusion 900 136". My question is whether a 144" track could fit or should I just go to a 156"-159" I also have the stock drivers for the assault however I'm not sure if they will fit or not. Any advice helps
Drivers from 06-up will not fit on ur driveshaft. Speedo side is different.
You might get away with a 144. Will be close but shouldn't be much of an issue imo
The 144" extension will be fine. The difference in tunnel length between the RMK 144" and the assault was only and inch...which was probably just a Polaris "round number".
