05 900 Rmk 151 clutching
jtpolaris
Hello would any one have a clutch setup for a 151 05 900 rmk. Mods are modified airbox, slp can, boondocker nos, MTX weights, also blue/pink slp primary(I think I changed it a couple times trying to get max rpm right), regeared and bottom end is at indydan's right now.. I have not changed anything in secondary.
Thanks for any help. I ve done some searching and everyone seems to have longer tracks and the slp pipe.
Thanks
In the secondary clutch I added a delrin bushing and shim from Slp and it helped my sled engage, shift and backshift much better. I have a 05 900 with a 151 track, mods are Slp air box, Slp pipe and can, and a milled head. I hope this helps.
good info, but i think he needs more info...
what helix are you running?
what spring are you running?
i would a MIN of 2 derlin washers...one on EACH side of the spring...will really help it out..
You should consult IndyDan on this. Give him the info you gave above and you will be happy with the setup he tells you to use. Include elevation also.
Thanks guys for the info so far. I did talk to indydan today. He already had my crank done and he just got it monday morning. He is definitely a good guy to work with. He did give me a couple ideas on the secondary but now that I'm looking the spring rate is not available for the 98 clutch.
Here's the setup I am thinking.
66 44.46/6642.46 and either red pink or black white
Thanks again
Thanks again
that looks about right. several guys are running that combo with good results from what i hear. i was running the same helix with the red black and it wasn't too bad either
im running the same helix..2 washers, red/pink spring (last year) and using the black/white this year...
Thanks
Anyone have the above helix (66 44,.46-66 42,.46) that they want to sell. I did find it on dirtcheapsnow for $85, that seems to be the best deal.
Thanks
Thanks
Thanks
85 is a good deal i payed 100 for mine. I may have one for sale but it wont be till after the first of the year. i am trying the team tied secondary and if i like it and can get it dialed in i will sell my old stuff.
