My sled is 05 900 fusion completly stock at this point would like to get more bottom end It seems hard to get the track to spin if trying to gas around a corner or pop the front end up off a trail bump kinda takes the fun out of it !
VENTS! Throw a pipe w/"Y" and can, all sorts of theories on pipes, depending on where you live (mountains or flatlands) matters how you set it up. I put DynoPort "y"/pipe/can VForce reeds FNI intake and Dalton clutching, and I am very happy with it all( I don't ride in mountains either). You won't hang the ski's like many others will, but you'll be happy, it's a diferent type of power. I spent alot of time reading around this site and they know alot, spend time and read or be alittle specific on topics and you'll be lead the way you need to go.The track not spinning has more to do than gearing also, if you can't get the track to spin something is wrong. Don't waste your $ and time putting gears in if you can't spin yer track! (not accurate advise imo.) Go up to the "Before you buy" and read.My sled is 05 900 fusion completly stock at this point would like to get more bottom end It seems hard to get the track to spin if trying to gas around a corner or pop the front end up off a trail bump kinda takes the fun out of it !
it's kinda like a 350 Chevy and 454 Chevy motor or a small block Ford vs a 460. That's the best way I can discribe it. The cooling, I have to do the same, or atleast I thought I did but 160-165 wasn't that bad after all. But I've been debating on rad. remove but when out riding in normal/agressive riding I don't have a problem. It's just when we go into towns to fuel up or "putt' on a trail. I've learned a whole bunch on here compare to other sites, I'm not bashing other sites, just have learned more here. Where do you ride?well she spin the track but just doesn't seem to have low end punch that I would like I aint much fer going real fast but I do like to play around slow speed and that is where this thing is kinda dissapointing.
Nuther question while I am here why is everybody removing front cooler I have trouble enough keeping her cool ! lota times gotta break off from the pack cause there running to slow for my sled ! does this thing have a thermostat ?
yeah, been to 180 area once or twice but resolve that real quike by edge of trail, usually I'm around 130-135. Do you have vents? If not, get some they work!I would be happy with 165 F but if I am doing any putting around she likes to hang 180 to 190 any higher and I try to find some powder to hit or get going
