I've been having this problem with this sled for the last few years. It seems to come and go, but the sled seems to work better at high altitudes. It only bogged a couple times in Cooke the last trip last spring. But it doesn't seem to have the power it had when it was new. But when I rode it here it would in ND it would go to WOT and then it drops to 6000 rpm and holds there and you pump the throttle and sometimes it comes out of it and most times it wouldn't.
Now whats been done, injectors replaced by polaris two years ago they thought this was the problem, I replaced TPS as it was bad(we thought this was the problem, but it was just one problem) and set and checked again, I rebuilt the motor last fall and installed 06 pistons and had the crank done by Indy Specialty, I just checked Stator and TPS wiring, and other sensors.
Any other ideas. I"ve checked alot of things and am running out of ideas.
Thanks for any ideas.
