04turbo rx1 fuel questions
P
powerstarved
New member
:D 2004 alpine rx1, from my fuel regulater there are 2 fuel supply lines that run to carbs. one line is teed prior to carb, this line splits and one line goes to the carb assembly and the other is a return to tank.the supply line that splits and goes to the fuel tank, could i tee a fuel pressure gauge there?does the return line to tank fitting, does it have a hose inside the tank like the other supply line to fitting, want to change filter and dont want to get them crossed
That's kind of confusing, i dont think the fuel feed to the carb is Teed to the return line but maybe I'm reading it wrong
Anyway, you cant monitor fuel pressure on the return line
I used to measure my fuel pressure a couple times a year directly off the regulator
You could tee into the fuel feed hose I'm sure but it gives you more potential for a high pressure fuel leak and that's scarry on a front mount
I would mount the gauge as close to the reg as possible if i were you
Oh, the return line has no hose inside the tank
