04 rev(hard starting)
Make sure all the rubber connected to the carb is tight with no cracks and holes. Check your fuel lines for cracks and holes. Cleaning the carb is great idea too. Maybe there is something going on with the choke.
Check your compression. 03-05 800HO had bad rings. They all need to be replaced no matter how many miles on them.
Pull the y pipe and look to see if the rings are faking. Compression should be at around 145 or higher.
what he sai ..had the same thing go down with mine ....just seemed to be a pig to start was down on compression ...honed her out and added new rings
