I have a King Cat with a rebuilt motor I am trying to get running. Both heads are ported, had to have one repaired and re-niked. New pistons and rings. It has some kind of high compression head on it. When I put both plugs up against the side of the head they will both fire, but not until the third pull. I can put one plug in at a time and get it to fire, with a spark tester on it, again after the third pull. When I put both plugs in neither will fire, according to the spark tester, no matter how many times I pull it. This is driving me crazy!!
Anybody seen this before???
I tried putting some spray in to see if the tester was the problem, not even a hint of fire.
BTW, there is no gas in the carbs yet, still have to prime the pump. I'm just checking for good spark before I take that step.
I'm thinking maybe the compression is to high and blowing the spark out with both plugs in?
Any ideas?
Did I install something wrong in the stator area and somehow the timing is way off?
Why does it only start sparking after 3 pulls?
Any ideas?
