04 800 won't run right
Rebuilt 04 800 summit will start and idle perfectly but after it warms up to temp won't run past half throttle. Its not the teather and local skidoo dealer is stumped. Any ideas?
Thanks for any help!
I should have mentioned that if the throttle is held at the correct position it will die if you let off of ithe throttle it will idle perfectly. Do these sleds have throttle pos. Sensors?
Check the stator for proper output... once they get warm a failing stator will give you similar symptoms
