Howdy. I am new here, think I dumped my intro so please bear with me.
My 04 800 159 runs extremely well under power. Has never failed me on a climb or on the trail. Problem comes against a closed throttle. When coming off a steep climb it will start to pop and the tach will drop off unless I feather the throttle. When I get back on the flat I have to keep feathering until I get it to idle. At that point it may stay running fine or after a short while will suddenly die. Starts up immediately after with a quick pull on the rope. Also, after a run down the trail, when I come to a stop the engine will pop as it idles down. When it does the tach dives off. Again I can feather it down and it may hold or it may not. Has never overheated and the plugs show I'm running a little fat but does not load up. Altitued doesn't seem to make a lot of difference. Would appreciate any thoughts
