900 Sale fell through... 700 still available too
I'm done. Kids in college and other hobbies.
You guy's have heard on this forum my 900 has had zero issues.
SLP Perf pkg...approx 2700 miles on that and 5800 overall. Compression test this year was 125 both sides and crank runout is right in the middle of factory spec. New 163" track and that has turned her into a better animal.
Also: Holz spindles, better boards, new hifax, new oiler cable and motor mounts, new OEM reeds, new exhaust valve bellows and gaskets, fresh NGK plugs with SLP plug wires and caps, new coil over springs on front shocks, fresh ceramic coating on pipe and can, new primary spring and clutch weight pin bushings, new jack shaft bearings, fresh chain case oil, radiator delete kit, vents, 19-43 gears, 74gr MTX adjustable weights, 64/38 helix and red/black secondary spring. All set up for deep snow and boondocking with new 163 track and 8" two wheel kit....I could have left something out.
$2600.00. This isn't your stock 900 and she is rock solid in reliability.
The 04 is a vertical edge 700 151" track and bone stock except for the SLP pipe and can.
Approx 2600 wife and kid miles. $3200.00
Make me an offer I can consider.
Call or text 208-819-1648 for more info or pics
