03 vertical escape 800 159
R
rmk8001
sled was a 159 rmk 800 vertical escape snow check.
heres whats left
primary- great cond.
secondary tss-98w/reverse helix great cond.
renthal bars
tm-40 carbs great cond.
rear bumper. two holes drilled for a rack
front bumper. good cond
head light good cond.
tail light. good cond
tach w/reverse signal
hayes brake. good cond
full steering rack.great cond
spindles great cond. no slop
steering arms
coolant bottle. good cond. not egg shaped
recoil assembly
both coolers
oil pump w/ reverse
cdi w/reverse
coil
voltage regulator
wiring harness great cond
lightweight jack shaft
full 159 rear suspension
torque stop clutch side great cond.
choke cable assembly
this is everything if you see something you need or would like some pictures pm me
and we will work out a price im located in truckee ca,
than you
