03 summit x 800 electrical problem
I took my summit 800 2003 out for the first time this year, it started up fine but none of my gauges or lights worked, i checked the fuses under the hood on the right side they looked fine. Does anyone have any idea as to what i need to check next. Thanks gravityxxx.
"AR143" is the part number you need. It is located right above the secondary.
It was $9.99 at Napa and with my discount it was $6.97
I replaced the same relay last year but i thought it was on the other side by the oil tank. I had the same issue and the relay is a common problem, get it at napa not a stealer.
