03 Summit sits low
The wifes 03 700 Summit adrenaline sits really low in the front end, is this normal. The one time I had it out it was like a snowplow. Will new Shocks help lift it up. Compared to my 03 RMK it sits about 2 inches lower. Thanks
snowplow
Try adjusting the springs, look at the bottom of the spring, there are different setting to adjust the height. Replacing the shocks won't help for height, replacing the spring could help if they are sagging.
You could also try setting up the center shock in the rear suspension and letting out the limiter strap one hole, this will take weight off of the front suspension when you sit on it. Try setting the center shock at the middle of the adjuster ring and go from there, you may have to tighten it up from there.
